Class 4 (4th Engineer) SSEP 📅 Sep 2022
Mechanical foam used for fire fighting is produced by mechanically mixing and agitating:
(a) Soda acid and water - True/False
(b) Dry chemical and water - True/False
(c) Inorganic/ Organic liquid with water and air - True/False
Justify your answer with suitable sketch and details of working (20)
### Evaluation of Statements
* **(a) Soda acid and water - False.**
This combination produces **Chemical Foam**. The process involves a chemical reaction between an alkaline solution (sodium bicarbonate) and an acidic solution (like aluminum sulphate). The reaction generates Carbon Dioxide (CO2) gas, which is trapped in the liquid to form a bubble structure. This method is largely obsolete on modern vessels in favour of more efficient mechanical foam systems.
* **(b) Dry chemical and water - False.**
