Class 4 (4th Engineer) MEKG 📅 Mar 2026
(a) Whilst on 'seawatch' you observe that the Oil Mist detector (OMD) in the engine room has triggered an alarm and in feeling the crankcase doors on the bottom platform you find that the unit in question feels warmer than the rest. What preemptive action will  you take as Watch-keeper to bring the situation under control. (10)
(b) Draw a simple line diagram of a "OMD" and explain it's working. (6)
### Principle of Summation in Marine Engineering
The operation of summation, or addition, is a fundamental mathematical principle that forms the bedrock of countless critical calculations performed onboard a vessel. While seemingly elementary, its correct and diligent application is paramount for ensuring the safety of the vessel, the crew, and the protection of the marine environment. In the context of Marine Engineering Knowledge (MEKG), this operation is integral to load calculations, fuel management, stability assessment, and performance monitoring. An error in a simple summation can lead to catastrophic failures, such as exceeding structural load limits, engine overload, or loss of stability.
### Problem Statement
The candidate is required to determine the sum of two given numerical quantities: 10 and 20.
