(a) What is the purpose of AVR in an alternator? (6)
(b) With the aid of a simple circuit diagram explain the basic working of a brushless alternator (10)
### (a) Purpose of AVR in an Alternator
An Automatic Voltage Regulator (AVR) is an indispensable component in an alternator system, primarily designed to maintain the alternator's output voltage at a constant, predetermined level regardless of varying operating conditions. Its comprehensive purpose can be detailed as follows:
* **Voltage Stability and Regulation**: The fundamental purpose of an AVR is to regulate the excitation current supplied to the alternator's main field winding. By precisely controlling the magnetic field strength within the alternator, the AVR ensures that the terminal voltage remains within tight specified tolerances (typically ±1% to ±2.5%) even when the electrical load connected to the alternator fluctuates significantly. This prevents voltage dips during load application and voltage surges during load shedding.
* **Load Compensation**: When an electrical load is connected to an alternator, especially inductive loads, the terminal voltage naturally tends to drop due to internal voltage drops across the armature resistance and reactance (often referred to as armature reaction). The AVR continuously monitors this voltage. If a drop is detected, it automatically increases the excitation current to counteract the effect of armature reaction, thereby boosting the internal generated voltage and restoring the terminal voltage to its set point. Conversely, if the load is reduced, the AVR decreases excitation to prevent an undesirable voltage rise.
