Class 4 (4th Engineer) MET 📅 Jul 2025
(a) Shunt generators having drooping characteristics are best suited for parallel operation. Discuss. (6)
(b) Two 220 V d.c. generators each having linear external characteristics, operated in parallel. One machine has a terminal voltage of 270 V on no-load and 220 V at load current of 35 A, while the other has a voltage of 280 V on no-load and 220 V at 50 A. Calculate the output current of each machine and the bus bar voltage when the total load is 60 A. What is the kW output of each machine under this condition. (10)
**Error Generating Answer:** Invalid control character at: line 2 column 6036 (char 6037)
