Class 4 (4th Engineer) MEP 📅 Jun 2025
(a) Describe the components forming part of a Gear Pump. Explain how pumping is carried out by a gear pump? (8)
(b) By suitable drawing describe what is 'back lash' and enumerate it's importance.
How is 'back lash' measured? (4)
(c) What checks will be carried out during overhauls. (4)
### (a) Gear Pump: Components and Working Principle (8 Marks)
**Components of an External Gear Pump:**
A gear pump is a simple rotary positive displacement pump. Its primary components are:
* **Casing/Housing:** This is the main body of the pump which encloses all other parts. It is precision-machined to provide minimal clearance for the gears. It contains the suction and discharge ports.
