Class 4 (4th Engineer) MET 📅 Sep 2025
(a) With reference to a three phase shipboard electrical distribution system:
Enumerate the advantages of an insulated neutral system; (4)
(b) Enumerate the disadvantages of an insulated neutral system; (4)
(c) State why an Earthed neutral system may be earthed through a resistor; (4)
(d) Compare the use of an insulated neutral system as opposed to the use of an Earthed neutral system with regard to the risk of electric shock from either system. (4)
### (a) Advantages of an Insulated Neutral System
An insulated neutral (or unearthed) system is one where there is no intentional connection between the neutral point of the generator or transformer and the ship's hull (earth). Its primary advantages are centered on ensuring the continuity of power for critical systems.
1. **Continuity of Supply:** This is the most significant advantage for maritime applications. In the event of a single phase-to-hull (earth) fault, a short circuit path is not established. The system continues to operate without interruption. This is critical for maintaining propulsion, steering, and navigation systems, thereby ensuring the safety of the vessel, crew, and cargo as mandated by SOLAS.
2. **Low Earth Fault Current:** The fault current during a single phase-to-earth fault is limited to the capacitive charging current of the system, which is typically very small. This minimizes the risk of damage at the fault location, such as burning out motor windings or damaging core laminations.
