Class 4 (4th Engineer) MEKM 📅 Nov 2025
(a) Compare the desirable qualities of the lubricating oil selected for each of the following duties: (16)
(i) Auxiliary diesel engines,
(ii) Stern tube bearings,
(iii) Refrigeration compressors
(iv) Gear case of purifier
Give reason for the differing properties of the oils recommended for these four purposes.
### Introduction
The selection of a lubricating oil is a critical engineering decision dictated by the specific operating conditions of the machinery it serves. A single oil cannot meet the diverse demands of different systems. The fundamental purpose of any lubricant is to reduce friction, minimize wear, remove heat, and prevent corrosion. However, the unique environmental challenges—such as temperature extremes, pressure, contamination risks, and fluid compatibility—necessitate specialized formulations. This answer compares the desirable qualities of lubricating oils for four distinct marine applications, highlighting why their properties differ significantly.
### (i) Auxiliary Diesel Engines
**1. Operating Environment:**
