Class 4 (4th Engineer) MET 📅 Sep 2025
(a) Describe the principle of operation of EACH of the following detecting elements: (8)
(i) Bi-metal strips
(ii) Thermisters
(b) Explain, with the aid of sketches, typical applications where the devices described in (a) may be employed in high voltage electrical systems. (8)
### (a) Principle of Operation of Detecting Elements
#### (i) Bi-metal Strips (8 marks)
**1. Fundamental Principle:**
The operation of a bimetallic strip is based on the principle of **differential thermal expansion**. This principle relies on two key physical properties of metals, as stated in the reference material:
