Class 4 (4th Engineer) MET 📅 Jun 2025
(a) Sketch a circuit diagram for an automatic voltage regulator illustrating how the A.V.R. utilizes a silicon-controlled rectifier to control the excitation system for an alternator. (10)
(b) Describe how the A.V.R. monitors output and controls the excitation system. (6)
### (a) Circuit Diagram for an Automatic Voltage Regulator (AVR) with SCR Control
A detailed circuit diagram is required to illustrate the functional blocks of an SCR-based Automatic Voltage Regulator for a brushless alternator. The diagram must clearly show the following key sections, interconnected to form a closed-loop control system:
1. **Sensing Circuit:** A three-phase step-down transformer (star-delta connection) connected to the alternator output terminals. The secondary of this transformer feeds a three-phase bridge rectifier, followed by an L-C (inductor-capacitor) smoothing filter. The output is a smooth DC voltage proportional to the alternator's terminal AC voltage.
2. **Reference and Comparator Circuit:** A Zener reference bridge circuit. This circuit takes the sensed DC voltage from the sensing circuit and compares it against a stable reference voltage provided by a Zener diode. The output of this stage is an 'error voltage', representing the deviation of the actual terminal voltage from the desired setpoint.
