Class 4 (4th Engineer) SSEP 📅 Nov 2025
(a) Sketch a simple line diagram showing a shipboard oily water separator in series with a coalescing second stage. (8)
(b) Briefly describe the above arrangement and its operations; also state the allowable oil content in p.p.m. of the discharge effluent from such an arrangement. (8)
(c) Explain how oil density and temperature relate to separation. (4)
### (a) Sketch of Oily Water Separator Arrangement
A simple line diagram should be drawn by the candidate. The sketch must clearly show the following components connected in the correct sequence:
1. **Suction Source**: Bilge Holding Tank.
2. **Pump**: OWS Feed Pump (positive displacement type, e.g., screw or reciprocating, to avoid further emulsification of oil).
