(a) What are the different types of coupling bolts used in practice? Name at least 3. (3)
(b) Explain with the help of sketch, as to how a 'pilgrim' hydraulic bolt is fitted and removed? (8)
(c) How are fitted bolts installed on the coupling? (5)
### (a) Types of Coupling Bolts
Based on design and application for transmitting torque and maintaining alignment in shaft couplings, three primary types of bolts are used:
1. **Fitted Bolts (Parallel Shank Bolts)**:
* These bolts have a precisely machined parallel shank that fits into an equally precisely reamed hole in the coupling flanges.
