Class 4 (4th Engineer) MEP 📅 Jun 2025
(a) There are three auxiliary engines having separate quick closing valves in the fuel supply line. How will you safely test these valves for each of the engines without causing a blackout? Discuss the process with the help of a diagram. (6)
(b) How will you reset the quick closing valves after the test is completed? (4)
(c) Explain the significance of flywheel marking on a four stroke engine. (6)
### (a) Safely Testing Quick Closing Valves (QCVs) for Auxiliary Engines without Causing a Blackout
Testing of Quick Closing Valves (QCVs) is a critical safety procedure to ensure their operability in an emergency, such as an engine room fire. To perform this test safely on multiple auxiliary engines without causing a blackout, a systematic approach focused on load management and operational safety protocols is essential.
#### **1. Preparation and Pre-Test Checks:**
* **Risk Assessment**: Conduct a thorough risk assessment for the operation, identifying potential hazards and implementing mitigation strategies.
