Class 4 (4th Engineer) MEP 📅 Nov 2025
(a) How are heat exchangers protected from the effects of corrosion? (8)
(b) What are the problems associated with bio-fouling? (8)
### (a) How Heat Exchangers are Protected from Corrosion
Protection of marine heat exchangers, particularly those using seawater as a cooling medium, is a multi-faceted approach involving material selection, electrochemical protection, design considerations, and rigorous operational maintenance.
**1. Material Selection (Primary Defence)**
The choice of materials is the first line of defence against corrosion. Different components are constructed from materials specifically chosen for their resistance to the fluid they will contact.
