Class 4 (4th Engineer) MEKM 📅 Nov 2025
(a) State the different types of turbo charger fitted in modern diesel engines. (8)
(b) Describe the function of the (8)
(i) nozzle ring,
(ii) labyrinth seals,
(iii) diffuser, and
(iv) inducer.
### Part (a): Types of Turbochargers in Modern Diesel Engines (8 Marks)
Turbochargers fitted to modern diesel engines can be classified based on several criteria, primarily gas flow path, bearing design, and turbine geometry. For full marks, a comprehensive answer should cover these aspects.
**1. Classification by Gas Flow Path:**
This is the most fundamental classification, as described in the provided context.
