Class 4 (4th Engineer) MEKM 📅 May 2024
(a) Briefly explain the construction and functions of a bedplate in a slow speed marine diesel engine? (8)
(b) How is the bedplate fastened to the hull structure? (4)
(c) What is the function of the tie-rod in a slow speed 2-stroke engine? (4)
### (a) Construction and Functions of a Bedplate in a Slow Speed Marine Diesel Engine
**Construction:**
The bedplate serves as the fundamental lower structure of a large slow-speed marine diesel engine, providing the main support for the crankshaft and distributing engine loads to the ship's hull. Its construction is meticulously designed for rigidity, strength, and durability.
* **Material:** Typically constructed from either high-quality cast iron or fabricated steel sections. Modern large engines often use fabricated steel for its strength-to-weight ratio and ease of repair, while cast iron offers excellent vibration damping properties.
