(a) Describe a pressure relief device fitted on a diesel engine crankcase. Are these devices fitted on all sizes of the engine? (8)
(b) What attention do crankcase pressure relief device require? (4)
(c) Name the factors which must be present for an explosion to occur in the crankcase of a diesel engine. (4)
### (a) Crankcase Pressure Relief Device: Description and Application
#### 1. Description and Operation
A crankcase pressure relief device, commonly known as a crankcase relief valve or door, is a critical safety fitting designed to relieve any sudden and excessive pressure rise within an engine's crankcase, thereby preventing a catastrophic structural failure. Its secondary, and equally vital, function is to contain the flame front from a primary explosion, preventing it from igniting the surrounding atmosphere and causing a more violent secondary explosion.
**Constructional Features:**
