Class 4 (4th Engineer) MET 📅 Dec 2023
(a) Describe a simple single phase transformer. (6)
(b) A 15 KVA, 440/110-volt, 50Hz cycle/sec, single-phase transformer has primary and secondary resistances of 0.12 ohm and 0.0077 ohm respectively. The iron loss of the transformer is 0.16 kW. Calculate the efficiency of the transformer (10)
(i) On full load unity power factor
(ii) On 80 per cent full load at a power factor of 0.9 lagging
### (a) Description of a Simple Single-Phase Transformer
A simple single-phase transformer is a static electrical device that transfers electrical energy from one circuit to another through the principle of electromagnetic induction without a change in frequency. It is primarily used to step up or step down alternating voltage and current levels. Its operation relies on the phenomenon of mutual induction between two or more windings linked by a common time-varying magnetic flux.
**1. Principle of Operation:**
* When an alternating voltage is applied to the primary winding, it draws an alternating current. This current produces an alternating magnetic flux in the laminated iron core.
