Class 4 (4th Engineer) MEP 📅 Feb 2024
(a) Describe different components used in soldering process. (6)
(b) Describe soldering process in detail. (6)
(c) What are Do's and Don'ts for good soldering joint. (4)
### (a) Components Used in Soldering Process
The primary components required for effective manual soldering, particularly in electronics and electrical applications, are as follows:
1. **Soldering Iron:**
* **Function:** This is the primary heating tool. It consists of a heated metal tip and an insulated handle. The tip transfers heat to the parts to be joined, melting the solder.
