(a) Describe different components used in soldering process. (6)
(b) Describe soldering process in detail. (6)
(c) What are Do's and Don'ts for good soldering joint. (4)
### (a) Components Used in Soldering Process
The primary components and tools required for a successful soldering process are as follows:
1. **Soldering Iron / Station:**
* **Function:** The primary heat source used to melt the solder. A soldering station offers precise temperature control, which is critical for protecting sensitive electronic components and achieving consistent results.
