Class 4 (4th Engineer) MEP 📅 Oct 2025
(a) Describe how leak in a heat exchanger tube is detected? How to rectify leaky tube? (8)
(b) What are the common methods to enhance heat transfer of heat exchanger? (4)
(c) Describe reasons for poor performance of heat exchanger and actions to rectify the same. (4)
### (a) Leak Detection and Rectification in a Heat Exchanger
#### **Procedure for Leak Detection (Pressure Testing)**
1. **Isolation and Safety**: The first critical step is to isolate the heat exchanger from the system. This involves shutting and securing the inlet and outlet valves for both the shell-side fluid (e.g., Lube Oil, LT Central Cooling Water) and the tube-side fluid (e.g., Sea Water). The system must be depressurized, vented, and drained. Lock-Out/Tag-Out (LOTO) procedures must be strictly followed.
2. **Dismantling**: Remove the end covers (water boxes) from both ends of the heat exchanger. This exposes the tube plates and tube ends for inspection.
