Class 4 (4th Engineer) MEP 📅 Nov 2023
(a) Describe maintenance to be carried out on safety valve of Auxiliary Boiler to keep them in good order. (10)
(b) Describe procedure for setting safety valve. (6)
### (a) Maintenance of Auxiliary Boiler Safety Valves (10 Marks)
Maintenance on boiler safety valves is critical for the safety of the vessel and personnel. It is divided into routine in-service checks and periodic overhauls, typically conducted during surveys.
**1. Routine In-Service Maintenance (Weekly/Monthly):**
* **Easing Gear Operation:** The valve should be manually lifted using the easing gear when the boiler is under sufficient steam pressure (at least 75% of working pressure). This confirms that the valve disc and spindle are not seized in the body. A sharp, crisp closing sound upon release indicates good condition.
