(a) Describe the procedure for taking crankshaft deflections of Auxiliary Engine explaining
all precautions that must be observed. (8)
(b) Explain what deflection readings actually mean and suggest the action which must be taken should readings be outside values recommended by the engine manufacturer. (5)
(c) Describe a safe procedure for checking wear down of a main bearing.
