Class 4 (4th Engineer) MEP 📅 Jan 2026
(a) Describe the procedure for:
(i) Riveting work (5)
(ii) Removing a stud from the plates. (5)
(b) What are the essential tools required for the procedure in (a) above. (6)
### (a)(i) Procedure for Riveting Work (Hot Riveting)
Hot riveting is a traditional method for creating a permanent, high-strength joint, particularly in structural steelwork and pressure vessels. The process relies on the plastic deformation of a heated rivet and the clamping force generated upon its cooling.
**1. Preparation of the Joint:**
* **Surface Cleaning:** The faying (contact) surfaces of the plates must be thoroughly cleaned of rust, scale, grease, and paint to ensure maximum frictional grip.
