Class 4 (4th Engineer) MEP 📅 Nov 2023
(a) Describe the safe isolation procedure of centrifuges on board ships before starting maintenance work. (6)
(b) Describe maintenance schedule of centrifuge for satisfactory operation. (10)
### (a) Safe Isolation Procedure for Centrifuges
A systematic and rigorous isolation procedure is critical to ensure the safety of personnel before commencing any maintenance on a centrifugal separator. The following steps, incorporating a Permit to Work (PTW) system, must be strictly followed:
1. **Inform and Obtain Permission**: Inform the Duty Officer on the Bridge and the Engineer in charge of the watch (Chief Engineer/Second Engineer) of the intention to stop and work on the centrifuge. Make a relevant entry in the engine room logbook. This ensures the machine is not expected to be in service and prevents inadvertent attempts to start it remotely.
2. **Proper Shutdown Sequence**: Stop the centrifuge from its local control panel. Allow the machine to come to a complete stop naturally. Do not use the brake harshly unless in an emergency, as this can cause undue stress. The rundown time should be monitored; a significantly short rundown time may indicate bearing or friction issues.
