Class 4 (4th Engineer) MEP 📅 Mar 2024
(a) Describe the uses of packed gland seal. What are the machineries they are in use? In a running pump, how the gland packing is lubricated and kept cool? (6)
(b) Describe advantages of using gland packing. (5)
(c) Describe disadvantages of using gland packing. (5)
### (a) Uses of Packed Gland Seal, Machineries in Use, and How Gland Packing is Lubricated and Kept Cool
A packed gland seal, often referred to as a stuffing box, is a fundamental sealing arrangement used to prevent the leakage of fluid (liquid or gas) along a rotating or reciprocating shaft where it penetrates a pressure boundary, such as a pump casing or valve bonnet. It also serves to prevent the ingress of atmospheric air or contaminants into the system.
**Primary Uses:**
* **Fluid Containment:** To prevent the escape of the process fluid from the machinery to the surrounding environment.
