Class 4 (4th Engineer) SSEP 📅 Nov 2024
(a) Describe, with the aid of a sketch, the braking arrangement for the controlled lowering of life boats (10)
(b) State the periodic survey requirements relating to the wire rope fall of lifeboats (10)
### (a) Lifeboat Winch Braking Arrangement
This system is designed to allow the controlled lowering of a lifeboat under gravity, ensuring a safe descent speed and the ability to stop the descent at any point. The arrangement primarily consists of a fail-safe manual brake and an automatic centrifugal brake.
The system operates on a fail-safe principle. A 'dead man's handle' or brake lever must be actively held by an operator to release a primary brake, allowing the boat to lower under its own weight. An independent, speed-sensitive centrifugal brake automatically engages to limit the lowering speed to a safe value as prescribed by SOLAS (typically not exceeding 1 m/s), irrespective of the operator's action on the manual brake lever.
