Class 4 (4th Engineer) MEKG 📅 Dec 2025
(a) Draw a simple line sketch of a 'shell and tube' cooler, clearly labelling its parts. (6)
(b) Describe the system. (4)
(c) Name common defects found. (3)
(d) What periodical maintenance, needs to be carried out. (3)
### (a) Sketch of a 'Shell and Tube' Cooler
A simple line sketch of a single-pass shell and tube cooler is required. The sketch should clearly illustrate the flow paths of the two fluids and label the following essential components to achieve full marks:
* **Shell:** The outer casing containing the tube bundle.
* **Tube Bundle/Stack:** The assembly of tubes through which one fluid flows.
