Class 4 (4th Engineer) SSEP 📅 Jan 2025
(a) Draw and explain a fixed Foam fire fighting system. (12)
(b) What is the proportion ratio of both high expansion and low expansion Foam fire fighting system? (4)
(c) What periodic test are carried out to ensure the readiness of the fixed foam fire fighting system? (4)
### (a) Fixed Foam Fire Fighting System: Explanation and Diagram
A fixed foam firefighting system is a permanently installed system designed to control and extinguish Class B fires (flammable liquids) in high-risk areas such as machinery spaces, boiler rooms, pump rooms, and on the decks of tankers. The system operates on the principle of creating a cohesive foam blanket over the surface of the burning liquid.
**Principle of Fire Extinction by Foam:**
Foam extinguishes a fire through a combination of three primary mechanisms:
