Class 4 (4th Engineer) MET 📅 Mar 2025
(a) Explain Fleming's Right hand rule. (6)
(b) A one-turn armature coil has an axial length of 0.4m and a diameter of 0.2m. It is rotated at a speed of 500 rev/min in a field of uniform flux density of 1.2T. Calculate the magnitude of the e.m.f. induced in the coil. (10)
### Part (a): Fleming's Right-Hand Rule (6 Marks)
Fleming's Right-Hand Rule is a fundamental principle used to determine the direction of the electromotive force (e.m.f.) or induced current in a conductor when it moves through a magnetic field. This rule is specifically applicable to electrical generators, where mechanical energy is converted into electrical energy.
**Principle:**
The rule is a direct application of Faraday's Law of Electromagnetic Induction, which states that a change in magnetic flux linkage with a conductor induces an e.m.f. across its ends.
