Class 4 (4th Engineer) MEKM 📅 Jan 2025
(a) Explain the advantages of fitting highly rated medium speed engines with double exhaust and air inlet valves. (6)
(b) State the disadvantages of double valve arrangements. (4)
(c) Explain the possible causes of persistent burning of exhaust valves if it is:
(i) General to most cylinders. (3)
(ii) Specific to a single cylinder. (3)
**(a) Advantages of fitting highly rated medium speed engines with double exhaust and air inlet valves (6 marks)**
The adoption of multiple (double) exhaust and air inlet valves in highly rated medium-speed engines is a sophisticated design choice driven by the need to optimise engine performance, efficiency, and durability under demanding operational conditions. The primary advantages include:
* **Enhanced Volumetric Efficiency and Gas Exchange:**
* **Larger Total Flow Area:** Two smaller valves can collectively provide a larger effective flow area than a single large valve for a given cylinder head diameter. This allows for more efficient induction of fresh air (inlet valves) and expulsion of exhaust gases (exhaust valves).
