(a) Explain the circumstances under which a two stroke engine fails to turn on air. (8)
(b) What investigations and corrective actions are required to be taken by you as a watchkeeping engineer if the engine does not turn on air after repeated trials? (8)
### (a) Explanation of Circumstances Under Which a Two-Stroke Engine Fails to Turn on Air
When a two-stroke main engine fails to turn on starting air, it indicates a critical issue within the starting air system, engine mechanics, or control system. As a Senior MEO Class 1 Examiner, a comprehensive understanding of these circumstances is crucial:
1. **Insufficient Starting Air Pressure:**
* **Problem:** The primary cause is often inadequate air pressure in the main starting air receivers. The engine requires a minimum pressure (typically 25-30 bar) to overcome internal resistance and provide sufficient torque for rotation.
