Class 4 (4th Engineer) MET 📅 Oct 2022
(a) Explain the term single phasing as applied to poly phase induction motors. (6)
(b) State the likely causes of single phasing and the consequences if motors are not adequately protected. (5)
(c) Describe with the aid of sketches THREE methods for motor protection should single phasing occur. (5)
### (a) Explanation of Single Phasing (6 Marks)
Single phasing is a fault condition in a three-phase electrical system where one of the three supply lines (or phases) to a polyphase induction motor is lost or disconnected. A three-phase AC supply is essential for creating a rotating magnetic field (RMF) of constant magnitude within the motor's stator, which is necessary for self-starting and smooth operation.
**Mechanism and Effects:**
1. **Loss of Rotating Magnetic Field (RMF):** When one phase is lost, the balanced three-phase system degenerates into a single-phase supply across the remaining two lines. This configuration can no longer produce a true RMF. Instead, it generates a *pulsating* or *oscillating* magnetic field.
