Class 4 (4th Engineer) MEKG 📅 Nov 2023
(a) Explain using a simple line diagram difference between lubricating oil systems dealing with cylinder lubrication vis-a-vis crankcase lubrication. (7)
(b) State the properties of oil essential in each of these cases. (4)
(c) What is synthetic oil ? How it is different from Mineral oil? Where is it used? (5)
### (a) Difference between Cylinder Lubrication and Crankcase Lubrication Systems
A marine slow-speed, two-stroke, crosshead-type diesel engine utilizes two entirely separate and distinct lubricating oil systems: one for the cylinders and one for the crankcase.
**1. Cylinder Lubrication System:**
* **Concept:** This is a 'total loss', 'once-through' system designed specifically to lubricate the interface between the piston rings and the cylinder liner. Its primary functions are to minimize friction and wear, create a seal between the rings and liner to prevent blow-by, and, most critically, to neutralize the corrosive sulfuric acid formed from the combustion of sulfur-containing heavy fuel oil.
