Class 4 (4th Engineer) MET 📅 Apr 2023
(a) Explain what is meant by the back e.m.f. of a motor. (6)
(b) A d.c. motor takes an armature current of 110 A at 480 V. The resistance of the armature circuit is 0.2 Ω. The machine has 6 poles and the armature is lap connected with 864 conductors. The flux per pole is 0.05 wb. Calculate (10)
(a) speed,
(b) the gross torque developed by the armature.
### (a) Explanation of Back E.M.F. (6 Marks)
**1. Definition and Principle:**
Back Electro-Motive Force (Back E.M.F. or $$E_b$$) is the voltage induced in the armature conductors of a DC motor as they rotate and cut the magnetic field lines produced by the field poles. This phenomenon is a direct application of Faraday's Law of Electromagnetic Induction, which states that an E.M.F. is induced in any conductor that cuts magnetic flux.
**2. Opposition to Supply Voltage (Lenz's Law):**
