(a) Explain, why is it important to measure bearing clearances in a diesel engine? (4)
(b) What is Bridge gauge? How is the Bridge gauge used? Explain with a diagram. (6)
(c) What are other recommended methods for checking bearing clearances. (6)
### (a) Explanation of the Importance of Measuring Bearing Clearances in a Diesel Engine
Measuring bearing clearances in a diesel engine is critically important for ensuring the engine's long-term reliability, operational efficiency, and structural integrity. Correct bearing clearance is fundamental for the proper formation and maintenance of the hydrodynamic lubricating oil film, which prevents metal-to-metal contact between moving parts. The key reasons for its importance are:
* **Formation of Hydrodynamic Oil Film**: Bearings are designed to operate with a continuous film of lubricating oil between the journal and the bearing shell. This oil film, generated by the relative motion and a specific clearance, carries the load and prevents direct contact. An incorrect clearance can impede the formation or maintenance of this film, leading to boundary or mixed lubrication.
* **Prevention of Metal-to-Metal Contact and Wear**: Sufficient clearance ensures that the oil film effectively separates the bearing surfaces. If the clearance is too small, the oil film cannot be properly established, leading to direct metal-to-metal contact, excessive friction, rapid wear (scuffing, wiping), and premature bearing failure. If the clearance is too large, the oil film can break down due to insufficient pressure generation, leading to impact loads and eventual contact.
