Class 4 (4th Engineer) MEKM 📅 Mar 2024
(a) Explain, why is it important to measure bearing clearances in a diesel engine? (4)
(b) What is Bridge gauge? How is the Bridge gauge used? Explain with a diagram. (6)
(c) What are other recommended methods for checking bearing clearances. (6)
### (a) Explanation of Importance of Measuring Bearing Clearances in a Diesel Engine
Measuring bearing clearances in a diesel engine is critically important for ensuring the engine's safe, efficient, and reliable operation. Bearings are fundamental components that support rotating and reciprocating parts, transmitting loads and allowing relative motion with minimal friction. Correct clearances are vital for maintaining the integrity of the hydrodynamic oil film, efficient load distribution, and preventing premature wear or catastrophic failure. The key reasons for this importance are:
* **Formation and Maintenance of Hydrodynamic Oil Film:**
* **Optimal Film Thickness:** Bearings rely on a thin, pressurized film of lubricating oil (hydrodynamic wedge) between the journal and the bearing shell to prevent metal-to-metal contact. Correct clearance allows for the formation and maintenance of this film, which supports the load and minimizes friction.
