Class 4 (4th Engineer) MET 📅 Aug 2024
(a) Explain why it is necessary to have reverse power protection for alternators intended for parallel operation. (6)
(b) (i) Sketch a reverse power trip. (5)
(ii) Explain briefly the principle on which the operation of this power trip is based and how tripping is activated. (5)
### (a) Explanation of Necessity for Reverse Power Protection in Alternators Intended for Parallel Operation
Reverse power protection is a critical safety and operational feature for alternators operating in parallel, preventing significant damage and ensuring system stability. The primary reasons for its necessity are:
* **Prevention of Motoring:** When an alternator's prime mover (e.g., a diesel engine, gas turbine) fails or loses sufficient power, that particular alternator can cease to generate electrical power. If it remains connected to the bus bar in parallel with other healthy alternators, it will start to draw power from the bus bar and operate as a synchronous motor. This phenomenon is known as "motoring" or "reverse power" operation.
* **Damage to the Prime Mover:**
