Class 4 (4th Engineer) MEP 📅 Dec 2024
(a) Explain with a sketch showing the components of an auxiliary engine fuel valve, the complete maintenance procedure including the removal of the fuel valve, pressure testing and overhaul. (12)
(b) What are the precautions to be taken before installation of a fuel valve on the Cylinder head? Indicate the special tools that may be required for the fuel valve removal and overhaul. (4)
### (a) Explanation of Auxiliary Engine Fuel Valve, Complete Maintenance Procedure, Pressure Testing, and Overhaul
A fuel valve (or fuel injector) in an auxiliary engine is a precision component responsible for atomizing and injecting fuel into the combustion chamber at the correct pressure, timing, and spray pattern. Its proper functioning is critical for efficient combustion, fuel economy, and prevention of engine damage.
#### Components of an Auxiliary Engine Fuel Valve
An auxiliary engine fuel valve typically consists of the following main components, which work in concert to achieve effective fuel injection:
