Class 4 (4th Engineer) SC&S 📅 May 2024
(a) Explains why the draught of a ship decreases when it passes from fresh water to seawater and vice versa (6)
(b) A bulkhead 9 m deep is supported by vertical stiffeners 750 mm apart. The bulkhead is flooded to the top edge with sea water on one side only. Calculate: (10)
(i) Shearing force at top
(ii) Shearing force at bottom
(iii) Position of zero shear
### Part (a): Draught Change with Water Density (6 Marks)
This phenomenon is governed by Archimedes' Principle, which states that the buoyant force acting on a submerged or floating body is equal to the weight of the fluid displaced by the body.
1. **Principle of Flotation**: For a ship to float in equilibrium, its total weight (Displacement, Δ) must be exactly balanced by the upward buoyant force (FB).
$$ \Delta = F_B $$
