Class 4 (4th Engineer) MEP 📅 Feb 2025
(a) How are heat exchangers protected from the effects of corrosion? (8)
(b) What are the problems associated with bio-fouling? (8)
### (a) Protection of Heat Exchangers from the Effects of Corrosion
Heat exchangers are critical components in marine engineering systems, and their protection from corrosion is paramount to ensure operational reliability, efficiency, and longevity. Corrosion can significantly degrade heat transfer surfaces, reduce operational lifespan, and lead to costly repairs and downtime. Protection strategies focus on material selection, electrochemical methods, chemical treatment, and design considerations.
1. **Material Selection:**
* **Corrosion-Resistant Alloys:** The primary defense against corrosion is the selection of materials inherently resistant to the operating fluid environments (e.g., seawater, fresh water, oil). Common choices include:
