Class 4 (4th Engineer) MEP 📅 Sep 2024
(a) How are heat exchangers protected from the effects of corrosion? (8)
(b) What are the problems associated with bio-fouling? (8)
### (a) Protection of Heat Exchangers from Corrosion
Heat exchangers are critical components in marine propulsion and auxiliary systems, and their continuous operation is paramount. Corrosion, a natural electrochemical process, can significantly degrade their performance, structural integrity, and operational lifespan. Protection against corrosion involves a multi-faceted approach combining material science, chemical treatment, electrochemical methods, and robust operational practices.
**1. Material Selection:**
* **Corrosion-Resistant Alloys:** The primary defense against corrosion is the judicious selection of materials appropriate for the operating environment. For seawater heat exchangers, common materials include:
