Class 4 (4th Engineer) MEKG 📅 Mar 2024
(a) How does fouling affect the performance of a heat exchanger? (4)
(b) Describe the types of plugs used to plug the ends of a leaky heat exchanger tubes. (6)
(c) What is a differential pressure gauge? Where is it used? (6)
### (a) How does fouling affect the performance of a heat exchanger?
Fouling refers to the accumulation of unwanted material on the heat transfer surfaces of a heat exchanger. This layer of deposited material acts as an additional resistance to heat transfer and can significantly degrade the unit's performance.
**Mechanisms and Types of Fouling:**
* **Precipitation Fouling (Scaling):** Occurs when inverse solubility salts (e.g., calcium carbonate, magnesium silicate) precipitate from the fluid onto the hot heat transfer surface. This is common in LT Central Cooling Water systems.
