Class 4 (4th Engineer) MET 📅 Jan 2023
(a) How protection is provided for electrical short circuit. (4)
(b) Describe the construction and operation of HRC fuses. (8)
(c) What are the advantages of HRC fuses. (4)
**(a) Protection for Electrical Short Circuits**
An electrical short circuit occurs when there is an abnormal, low-resistance path between two points in an electrical circuit that are meant to be at different potentials. This results in an extremely high, uncontrolled flow of current (fault current) which can cause severe damage to equipment, fire hazards, and personnel injury due to excessive heat generation ($$ P = I^2R $$), mechanical stresses, and arc flashes.
Protection against short circuits is fundamentally achieved by rapidly detecting the fault and isolating the faulty section of the circuit. The primary devices employed for this purpose are:
* **Fuses:**
