Class 4 (4th Engineer) MET 📅 Jan 2024
(a) How protection is provided for electrical short circuit. (4)
(b) Describe the construction and operation of HRC fuses. (8)
(c) What are the advantages of HRC fuses. (4)
### (a) Protection for Electrical Short Circuit
Short circuit protection in an electrical system is paramount to prevent catastrophic damage to conductors, equipment, and to mitigate fire hazards. A short circuit occurs when an abnormal, low-resistance path is established between two points of different potential, leading to a sudden and massive surge of current (fault current). Protection devices must detect this fault rapidly and interrupt the circuit before the fault current causes excessive heating or mechanical stress. The primary methods of protection against electrical short circuits include:
* **Fuses:** These are the simplest and fastest-acting short circuit protective devices. A fuse contains a metallic wire or element designed to melt and open the circuit when the current exceeds a predetermined value for a specific duration. They are sacrificial devices, meaning they must be replaced after operation.
* **Principle:** Based on the $$ I^2R $$ heating effect. When fault current flows, the fuse element rapidly heats up and melts, interrupting the circuit. Modern fuses, such as High Rupturing Capacity (HRC) fuses, also incorporate arc-quenching media for rapid and safe interruption of high fault currents.
