Class 4 (4th Engineer) SSEP 📅 Sep 2025
(a) Illustrate with a diagram, how the engine room's hyper mist or high-pressure fog firefighting system works. Describe the sequence of events that occurs during automatic activation of a Hyper Mist system. (12)
(b) List the machinery spaces and equipment on a ship where a Hyper Mist system is typically installed. (4)
(c) Explain the manual activation procedure for the Hyper Mist system, both from the local control point and the main control panel. (4)
### (a) Working Principle and Automatic Activation Sequence of a Hyper Mist System
#### Principle of Operation
The Hyper Mist (or High-Pressure Water Fog) system is a fixed firefighting installation designed for machinery spaces. Its operation is based on discharging fresh water at very high pressure through specially designed nozzles, which atomize the water into a fine mist with a droplet size typically between 50-200 micrometers.
The fire extinguishing mechanism is threefold:
