Class 4 (4th Engineer) MET 📅 Dec 2023
(a) List the parts of an alternator fitted with temperature alarms. (6)
(b) Explain why heaters are fitted to an Alternator. (6)
(c) Explain the function of an automatic voltage regulator. (4)
### (a) Parts of an Alternator Fitted with Temperature Alarms (6 Marks)
For a marine alternator, continuous temperature monitoring is critical for preventative maintenance and avoiding catastrophic failure. Alarms are fitted to the following key parts, typically using Resistance Temperature Detectors (RTDs), such as Pt100 sensors, for accuracy and stability.
1. **Stator Windings:**
* **Reason:** This is the most critical monitoring point. Heat is generated in the windings due to copper losses ($$ I^2 R $$) from the load current and iron losses (eddy currents, hysteresis) in the core. Excessive temperature (above the insulation class limit, e.g., Class F: 155°C, Class H: 180°C) leads to rapid degradation and eventual failure of the winding insulation, causing short circuits.
