Class 4 (4th Engineer) MEKG 📅 Dec 2025
(a) Name the safety devices fitted on 2 stage air compressors on ships. Explain their functional purpose as well as location of fitment, using a schematic diagram. (12)
(b) State the maintenance and checks carried out periodically in order to keep them efficient. (4)
### (a) Safety Devices on a 2-Stage Air Compressor
Marine two-stage air compressors are high-pressure machines vital for engine starting, control air, and service air. Due to the high pressures and temperatures involved, they are fitted with several critical safety devices to protect the machinery and personnel. A failure in a compressor system can lead to mechanical damage, fire, or even a catastrophic explosion.
**1. Stage Relief Valves (1st and 2nd Stage)**
* **Location:** A relief valve is fitted on the discharge side of each stage, i.e., after the 1st stage cylinder (before the intercooler) and after the 2nd stage cylinder (before the aftercooler).
