(a) Shunt generators having drooping characteristics are best suited for parallel operation. Discuss. (6)
(b) Two 220 V d.c. generators each having linear external characteristics, operated in parallel. One machine has a terminal voltage of 270 V on no-load and 220 V at a load current of 35 A, while the other has a voltage of 280 V at no-load and 220 V at 50 A. Calculate the output current of each machine and the bus bar voltage when [10] the total load is 60 A. What is the kW output of each machine under this condition. (10)
