Class 4 (4th Engineer) MET 📅 Oct 2024
(a) Sketch a circuit diagram for an automatic voltage regulator illustrating how the A.V.R. utilizes a silicon-controlled rectifier to control the excitation system for an alternator. (10)
(b) Describe how the A.V.R. monitors output and controls the excitation system. (6)
### (a) Circuit Diagram for an Automatic Voltage Regulator (AVR) Utilizing a Silicon-Controlled Rectifier (SCR) for Alternator Excitation
An Automatic Voltage Regulator (AVR) is a crucial component in maintaining a stable output voltage from an alternator under varying load conditions and prime mover speed fluctuations. Modern marine alternators predominantly utilize static excitation systems controlled by solid-state AVRs, often employing Silicon-Controlled Rectifiers (SCRs) or thyristors for precise control of the excitation current.
#### **Basic Principles of SCR Operation in an AVR System:**
A Silicon-Controlled Rectifier (SCR) is a four-layer, three-junction semiconductor device that acts as a unidirectional current switch. It has three terminals: anode, cathode, and gate. An SCR will block current in both forward and reverse directions until its breakover voltage is exceeded or a small positive pulse is applied to its gate terminal while the anode is positive with respect to the cathode. Once triggered, it remains in the conducting state (latched ON) even after the gate signal is removed, as long as the anode current is above its holding current and anode voltage remains positive. It turns OFF only when the anode current falls below the holding current or the anode-cathode voltage becomes reverse biased.
