Class 4 (4th Engineer) MET 📅 May 2024
(a) Sketch a circuit diagram for an automatic voltage regulator illustrating how the A.V.R. utilizes a silicon-controlled rectifier to control the excitation system for an alternator. (10)
(b) Describe how the A.V.R. monitors output and controls the excitation system. (6)
An Automatic Voltage Regulator (AVR) is a crucial component in an alternator's control system, designed to maintain a stable output voltage under varying load conditions. In the context of the question, we will describe an AVR system that utilizes Silicon-Controlled Rectifiers (SCRs) for excitation control, a common approach in many marine alternators.
### (a) Circuit Diagram for an Automatic Voltage Regulator Utilizing SCRs
**Description of the SCR-based AVR Circuit:**
A typical SCR-based Automatic Voltage Regulator (AVR) for an alternator's excitation system operates on the principle of phase control to vary the DC current supplied to the alternator's main field winding (either directly or via an exciter field). The circuit comprises several key functional blocks:
